80 with Waukesha - Wet or Dry sleeves?
Kirk in PA
02-08-2005 12:54:43
I am restoring a 39 Huber with a Waukesha VIK21F engine which is the same as an Oliver 80. Does any one know if this engine has wet or dry sleeves?
RAB
02-08-2005 15:36:28
 Re: 80 with Waukesha - Wet or Dry sleeves? in reply to Kirk in PA, 02-08-2005 12:54:43
Just remember they fitted different sizes of piston/liner in the 80 engine.
Regards, RAB
Jim Kline
02-08-2005 15:05:50
The 80 engine has wet sleeves.
Kirk in PA
02-08-2005 15:22:32
 Re: 80 with Waukesha - Wet or Dry sleeves? in reply to Jim Kline, 02-08-2005 15:05:50
Thanks Jim
Dean Martin
02-08-2005 17:25:43
 Re: 80 with Waukesha - Wet or Dry sleeves? in reply to Kirk in PA, 02-08-2005 15:22:32
Is the same Jim Kline from Ohio that i talked to about 10 years ago when i was looking for parts for my 60 standard on steel?
Jim Kline
02-09-2005 14:23:12
 Re: 80 with Waukesha - Wet or Dry sleeves? in reply to Dean Martin, 02-08-2005 17:25:43
Yes Dean, I'm the guy. I remember you too. Not too many 60 Standards on full steel.
Dean Martin
02-09-2005 16:58:30
 Re: 80 with Waukesha - Wet or Dry sleeves? in reply to Jim Kline, 02-09-2005 14:23:12
Jim Kline check the Tractor Photos for the 60 Standard on steel!
