Cockshutt 40 rod bolts
Mr. C
02-08-2005 07:06:13
Does anybody know where I can get a set of rod bolts for a 40 gas? Agco discontinued them and my Agco dealer's "dealer network" computer only came up with one place that has them, and they only have 2, I'd like to get all 12. Thanks!
Mike (WA)
02-09-2005 12:29:53
 Re: Cockshutt 40 rod bolts in reply to Mr. C, 02-08-2005 07:06:13
Try these guys.
Smoke
02-09-2005 00:05:10
If Agco can only come up with 2 you probably will not be able to get any. These were not popular parts and most of the time were ordered from a dealer when needed. I beleive they are a 3/8ths bolt and there is a chance you local machinist may be able to find an automotive bolt that is close enough is could be used. You may have to grind the bolt shank down a bit or ream out the connecting rod but doing either will not hurt as long as the lenght is close enough it will tighten correctly. If you go this way use the torque spec. for the bolt you use. You really do not need the cotter pin holes and castelated nuts since their use has since been deleted in modern applicatins.
J. Schwiebert
02-08-2005 18:20:21
Did you check under a Cockshutt number or under an A-C number. Also David has a point. Ask your machine shop what brand of bolts he uses for automotive use. I would do a little more checking. You might not find any with the cotter key holes though. Questions?
Dave Sherburne, NY
02-08-2005 16:52:39
I would ask the machinist who is working on my engine .
Mr. C
02-09-2005 14:11:42
 Re: Cockshutt 40 rod bolts in reply to Dave Sherburne, NY, 02-08-2005 16:52:39
thanks for the help everyone...we found some out of a d19 allis gas (262) that will work perfectly.
