Robin Glennie (vickers vane pump)
steve_ne
02-07-2005 20:13:56
I readed an old post that you were looking for parts for a vickers vane pump v120. Did you happen to find a source? If so could you please share that bit of million dollar information with me.
Thanks.
KENT
02-08-2005 06:36:30
 Re: Robin Glennie (vickers vane pump) in reply to steve_ne, 02-07-2005 20:13:56
I HAVE SEVERAL GOOD V120 HYDRAULIC PUMPS OFF OF SUPER 55'S & 550'S FOR SALE--MY EMAIL IS OPEN OR CALL ME AT 903-729-8349---THANKS
KENT
Super 55
02-08-2005 19:40:59
 Re: Robin Glennie (vickers vane pump) in reply to KENT, 02-08-2005 06:36:30
Hey Kent, I don't know if you know, but make sure you match up this fellows pump with either early or late model pump. There is a difference in the location of the inlet and outlet holes. I was made aware of that working on my pump.
J. Schwiebert
02-08-2005 04:56:13
What model Vickers are you looking for. The model number will be stamped on the pump. If looking for an Oliver remember they are not all the same width.
P Heisey-Harleysville,PA
02-08-2005 03:14:15
steve ne,
I have the vane kits, shafts and other parts in stock. Do you have Vickers V-110 parts for sale?
Phil Heisey 215-256-8651 FAX 215-256-1203
steve_ne
02-08-2005 07:13:44
 Re: Robin Glennie (vickers vane pump) in reply to P Heisey-Harleysville,PA, 02-08-2005 03:14:15
I have a vickers v-110. I got it at an auction and thought it was all there. I was wrong The vanes and backplate are gone. This pump would be used for a loader on my ferguson using the crank shaft pulley.
Here is a picture of the part I'm missing.
Link
Do you have these parts?
Stamped on the back is v114351c10 but the 4 is stamped over the 0
J. Schwiebert
02-08-2005 18:17:20
 Re: Robin Glennie (vickers vane pump) in reply to steve_ne, 02-08-2005 07:13:44
Hey just remember that the V-110 was probably made in 5 different widths.That means there are 5 different vane widths too. You need to have more information. Also if you are going to use that as a front mounted pump, why not put a real pump us there, something in the 8-10 gallon a minute size at a moderate engine RPM of 12-1500 RPM. Questions. I also realize a Vickers is easier to reverse, but you need a counterclockwise rotation pump.
PHarrer
08-04-2006 00:22:34
 Re: Robin Glennie (vickers vane pump) in reply to J. Schwiebert, 02-08-2005 18:17:20
Mr Schwiebert, can you recommend a decent replacement in the 8-10 gal range? I'm looking to put one on my S 55 and was considering the Vickers 120... it did have a Cessna, but it was lost.
Thanks
