Generator Mounting Brackets 88
JDD61012
02-05-2005 12:00:27
Just purchased a 1952 oliver 88 gas. The tractor needs to have the generator mounted back on the tractor. We have the top bracket, which i guess you tighten the belt with but are missing the pivot/lower bracket(s). I would appreciate a picture of the brackets. If one is not available, we may fabricate one, but would like to see the original. Thanks for any help in advance. BILL
JDD61012
02-06-2005 10:03:18
 Re: Generator Mounting Brackets 88 in reply to JDD61012, 02-05-2005 12:00:27
Thank You! Picture is exactly what we needed, and luckily I believe we have all the parts to mount the generator back on....
jjld
02-05-2005 16:42:10
Best photo I have. One angle bracket at the rear and a spacer with long bolt in the front cover for the front end.
BrianC
02-08-2005 12:34:42
 Re: Generator Mounting Brackets 88 in reply to jjld, 02-05-2005 16:42:10
Hey jjld, would you have a picture of the carb fuel line? my 77 Row Crop (gasoline) is missing the fuel line, I'm trying to decide if I should use steel or copper, flair or compression fittings etc...
