OLIVER 55O LEAK
Allen L.
02-05-2005 11:55:01
I recently bought a 550 and noticed the transmission was completely dry. I poured in about 3 gallons of 10w30 oil which I thought was correct. It poured out the inspection plate for the PTO Adjustment. Would 90 wt do the same? In other words do I have a seal problem? Thanks, Allen
J. Schwiebert
02-05-2005 13:55:56
 Re: OLIVER 55O LEAK in reply to Allen L., 02-05-2005 11:55:01
I would say you have a seal problem. The center section between the engine and the transmission should be dry. You may have a problem with more than one seal.
Allen L
02-06-2005 16:14:11
 Re: OLIVER 55O LEAK in reply to J. Schwiebert, 02-05-2005 13:55:56
Where can I purchase the seals for the transmission? Will I need any special tools to pull the old seals. Thanks, Allen L.
J. Schwiebert
02-06-2005 18:33:09
 Re: OLIVER 55O LEAK in reply to Allen L , 02-06-2005 16:14:11
Do you have a manual? You will need to do what is know as a Z split of the tractor. A means of supporting the front of the tractor and a good floor jack will be necessary. You may also need to replace some needle bearings at least I would. If your tractor has a loader take it off first. You will need to fabricate a spaner wrench also. Questions?
jakej
02-06-2005 22:45:37
 Re: OLIVER 55O LEAK in reply to J. Schwiebert, 02-06-2005 18:33:09
I made a spanner wrench from a section of 2" pipe.Will e-mail photo if needed.
Allrn L
02-07-2005 06:05:22
 Re: OLIVER 55O LEAK in reply to jakej, 02-06-2005 22:45:37
You fellows are great! The tool you mentioned must be to remove and install the new seals. Is that correct? I have the owners manual which does talk about the split. Is there a more detailed manual I could purchase and if so could you tell me where to get it? Also where might I obtain new seals? Thanks again, Allen
jakej
02-07-2005 08:57:13
 Re: OLIVER 55O LEAK in reply to Allrn L, 02-07-2005 06:05:22
The spanner tool is used to remove a large nut holding the hub which the PTO friction discs ride inside. The method used by many is a long rod and a big hammer due to the angle involved this deforms the slots. The pipe tool I made is east off and on. This hub must be removed to replace "O" rings inside.
Allen L.
02-09-2005 05:21:53
 Re: OLIVER 55O LEAK in reply to jakej, 02-07-2005 08:57:13
Thanks for all you responses. Regards, Allen L.
