Oliver 1950 GM over /under?
Ryan w
01-31-2005 15:39:33
We found a 1950 GM he said the over under is out .I was wondering how much to rebuild this and how difficult.Have not seen tractor wanting to make a puller is a good or bad idea?
WFE
01-31-2005 21:21:41
 Re: Oliver 1950 GM over /under? in reply to Ryan w, 01-31-2005 15:39:33
Easy rebuild to do if you have the reference materials to do it. Depending upon what made this unit fail, you could be looking at as little as $150 for a seal kit, or over a thousand if you have to replace any of the shafts. A good rebuilt O/U will sure make a nice combination for a puller tractor.
j meyer
01-31-2005 17:10:00
the 1950 did not have an Over/Under, it would have the Hydra Power Drive. Is it a good puller, heck yeah! and its a screamer:)
Don-Wi
02-01-2005 20:52:40
 Re: Oliver 1950 GM over /under? in reply to j meyer, 01-31-2005 17:10:00
I think he meant to find an O/U and replace the hydra power with it. would be nice having an extra set of speeds.
Donovan from Wisconsin
Ryan w
01-31-2005 17:42:40
How does the Hydra Power Drive work? Is this a costly repair? I am new to these tractors alawys liked the old Detroits.
