Did the 1855 have a turbo?
TP from Central
01-31-2005 07:34:42
The more I think about it the more I want to sell the last IH I have and buy another Oliver. I was wondering if the 1855 was NA or has a Turbo? Is it best to go with something like a 1955 to get the turbo concerning the 310?
mike in mn
01-31-2005 18:20:12
 Re: Did the 1855 have a turbo? in reply to TP from Central PA, 01-31-2005 07:34:42
the 1855 came with a naturally aspirated 354 perkins diesel. which is a way better motor. the 310 waukeshaw is well known for blowing the head gasket. there is an after market turbo available for this tractor if you wanted a tractor with a turbo
AllanC
01-31-2005 19:40:53
 Re: Did the 1855 have a turbo? in reply to mike in mn, 01-31-2005 18:20:12
Not quite. The 1855 has the Wauk 310, The 1850 has the Perkins. And yes, it has a nice Garrett Turbo.
WFE
01-31-2005 09:08:42
1955 had a couple advantages over the 1855. Both used same turbo set-up, however, injection pump on the 1955 is slightly larger displacement. All 1955s had factory oil coolers, whereas only 1855s made 1974 and later had factory oil coolers. There was an aftermarket oil cooler available for these pre-74 1855s, and many have been fitted with it. You'll love either one. Research the archives here and you can read more on the 310. When looking at any prospective purchase of a 310, take a flashlight with you and look through the dipstick hole to see which rod bolts are installed. You want to see 12 point heads, not 6 point. Happy hunting!
earlschieb
01-31-2005 08:50:31
Ya got it bad, don't ya Tyler? Oilallover Fever!!!
TP from Central PA
01-31-2005 09:38:07
 Re: Did the 1855 have a turbo? in reply to earlschieb, 01-31-2005 08:50:31
Yeah, I'll admitt I do..... ....And I really hate using that 504 on a loader. With not even 3000 hrs on it and in good condition it should be a collectors tractor, not a worker.
VADAVE
01-31-2005 17:03:59
 Re: Did the 1855 have a turbo? in reply to TP from Central PA, 01-31-2005 09:38:07
You thinking about putting a loader on a1855?
If so you should talked to SHEP VA or look at some of the posts and pictures he has put up. He has a pretty big loader on a1855 and wound up replacingnthe front end to increase it's durability.
Doug S
01-31-2005 08:26:58
1855, 1955 has a turbo, 1755 does not.
