Tachometer, Electric part # 30-3385787
todd08
01-30-2005 07:22:05
I installed a believed to be NOS tach, on my tractor. Hooked all three wires up to their prospective lead, start tractor stays at 2000rpm. Did notice when you intially turn power on the needle does slightly move. But not more than 50 rpm. What do you think my problem is? I have the signal wire going to the little pin on the back of the alternator. As I stated earlier the tach has 3 additional wires coming out of the bottom, blue, white and green. I am assuming they are for something else like an idiot light. How does one test the signal wire output coming from alternator. Maybe this part is not correct or compatable, any help greatly appreciated. The guage does have 4 setting for the frequency, I am in the low position.
Doug S
01-31-2005 08:16:04
 Re: Tachometer, Electric part # 30-3385787 in reply to todd08, 01-30-2005 07:22:05
What model tractor are you installing this tach on? A 2-150 or 2-155? The 2-155 or 2-135 should have all wires need there in the dash and hooked up. 2-150's had a mechanical tach like the late Olivers with the only wires are for a light in it. In my parts book for a 2-155, I do not have this number listed, but it may have been superceded. If you need to be sure of an application, contact an AGCO dealer with the PN and ask them what it fits.
