2255 Valve protrusion
todd08
01-28-2005 19:04:56
What is the range for both Exh/Int valve protrusion on the 3150 heads enable to have correct compression?
J. Schwiebert
01-29-2005 21:31:39
 Re: 2255 Valve protrusion in reply to todd08, 01-28-2005 19:04:56
Check your piston height in relation to the deck height too. A Cat man told me a long time ago that not all blocks were the same length on both sides.
todd08
01-30-2005 06:25:38
 Re: 2255 Valve protrusion in reply to J. Schwiebert, 01-29-2005 21:31:39
I hope your not right in this case. My left bank is hot on all holes on initial start up, my right one has 3 very cold, one that does warm up without loading the engine a little. I rebuilt the engine w/o checking the valve recession, mistake one and second I did not check piston to deck height at top dead center on either side. If a guy thought the right bank was longer, can I compensate enough with re-working a head and making the valve recession less. Sure would like the thing to hit on all 8 w/o blue smoke. How about did your Cat man state that decks not being the same only apply to the little non-sleeved Cat V-8's or all. Fighting the same thing on a big One, It went together with all new injectors, and new plungers and barrels in the pump?
george md
01-28-2005 19:15:22
Todd,
Valves are below deck in that engine.
int--.036 to .068
ex -- .050 to .085
george
todd08
01-29-2005 17:26:32
 Re: 2255 Valve protrusion in reply to george md, 01-28-2005 19:15:22
Thanks George
J. Schwiebert
01-30-2005 16:56:42
 Re: 2255 Valve protrusion in reply to todd08, 01-29-2005 17:26:32
Todd I need to contact you I have a question.
J. Schwiebert
01-30-2005 16:04:55
Todd: See if you can find me on the HPOCA form
