Co-op @ Cockshutt 30
H.B. Hutchens
01-27-2005 18:35:37
Watch Tractor calander on RFD tonight, did I hear correctly that these 2 tractors use the Buda 153 ci engine, also that one model MH might also use it, have one I got out of an AC Forklift , courous as to what all it fit. Thanks H.B.
H.B. Hutchens
02-01-2005 08:52:58
 Re: Co-op @ Cockshutt 30 in reply to H.B. Hutchens, 01-27-2005 18:35:37
Mr. Schweibert, found 2 sets of numbers on right side of block, on the top part of block, 512403, the 403 was stamped in by hand after the 512, I assumethis is engine serial number. On the lower part of the block is 2562, all of which is part of the casting. Appreciate your assistance in identifing this engine. H.B.
H.B. Hutchens
01-30-2005 17:58:06
Have no idea if AC or Buda, how do you tell difference, my assumption of Buda was based on info from previous posting that said Buda,s were used in AC forklifts. H.B.
J. Schwiebert
01-31-2005 05:47:04
 Re: Co-op @ Cockshutt 30 in reply to H.B. Hutchens, 01-30-2005 17:58:06
A-C reengineered the engines and called them A-C engines. A lot of parts interchange a lot will not. Do you have any casting numbers?
J. Schwiebert
01-29-2005 21:47:53
Do you have a Buda 153 or an A-C 153 engine? Also this is going to blow some of the Oliver guys minds but there are 155 Cubic inch Waukesha engines in Clark fork lifts and if you look at them they are totaly different in the front.
H.B. Hutchens
01-28-2005 08:02:53
Thanks, appreciate the responses. H.B.
krm
01-28-2005 06:49:34
You heard correct the b153 buda was used in the co-op e-3 and cockshutt 30,same tractors,different names.
H.B. Hutchens
01-27-2005 19:51:32
I probaby misunderstood, half watching and reading paper, I take it they were in the co-op and cockshutt. Thanks for the quick reponse. H.B.
edchainsaw
01-27-2005 19:20:16
I never new a MH to have one--- most of their engines came out of continental or chrysler plants.... but that dont mean its not true.
Kevin in Wi
01-28-2005 11:43:14
 Re: Co-op @ Cockshutt 30 in reply to edchainsaw, 01-27-2005 19:20:16
the b153 and slant 6 chrysler are identicle in their match up to the bell housing. I know a guy who in fact put a slant 6 in his co-op e3/cockshutt 30.
