water in the oil of my 77
Ben Oregon
01-24-2005 17:12:38
I�ve started to notice water in my oil of my 1948 77. I removed the head and checked the gasket and couldn�t see any signs of damage. (But I wasn�t really sure what I was looking for) The head gasket that was in the tractor was fairly new, I had rebuilt the top end of the engine about a year ago. The only conclusion that I could come up with is that I never re-torque the head down. Or is there any way that the water pump is maybe leaking into the lubrication system?
old
01-24-2005 17:28:04
 Re: water in the oil of my 77 in reply to Ben Oregon, 01-24-2005 17:12:38
Is it water or antifreeze? If its just plane water it could be condensation and or rain water from the exhaust/air cleaner. You could also have a sleeve leak or a crack some where.
cobroller
01-24-2005 19:38:55
 Re: water in the oil of my 77 in reply to old, 01-24-2005 17:28:04
I agree with Old. I have pulled the pan and poured the block full of water and waited for it to start dripping. Could be the liner orings. Don"t do this if its below freezing.
Billybob-Ia.
01-25-2005 13:09:24
 Re: water in the oil of my 77 in reply to cobroller, 01-24-2005 19:38:55
I was getting antifreez (very small amount) in the oil, took the valve cover off and two of the frost plugs on top of the head were seeping. Boy did I Feel lucky, problem is fixed. Billybob-Ia.
c zurn
01-26-2005 16:18:16
 Re: water in the oil of my 77 in reply to Billybob-Ia., 01-25-2005 13:09:24
I hope its just a plug, mine turned out to be a crack in the bottom of the block between #4 liner. Had to buy a used block from Wengers. Best of luck !! Charles
