66 crank strength
deenw
01-23-2005 10:51:14
want to put 3 3/4 sleeves and pistons in my 66 to pull with..was told that the stock crank would not hold up..anyone shed light on this or alternatives for me?..thanks
stroker88
01-24-2005 17:07:15
 Re: 66 crank strength in reply to deenw, 01-23-2005 10:51:14
have a welded stroker at 5" with a 2" rod pin. makes about 55 hp at 540 pto. turn it about 2600, will pull down on dyno to about 300 hasn't broke yet. why worry about 3 3/4" bore?
deenw
01-24-2005 20:47:03
 Re: 66 crank strength in reply to stroker88, 01-24-2005 17:07:15
have had a few pullers say that they have broken cranks in straight 77,s with 3 3/4 pistons....dont know whether they were put together right or not..most say that when they went to a super crank they never had a problem anymore..i figured it might be due to the smaller rod journal dia. just figured i would get some input for those who know before i put this thing together..am operating on a budget and just want to have some fun but want to be a little competition rather than just a donation to the other members of the association...thanks for your comments and interest everyone on here has been very helpful
tough 66
01-24-2005 09:17:43
We have been pulling a 66 for quite sometime. We have had the camshaft reground for more bottom end torque. REALLY made a big difference. Might consider doing the same.
66 owner
01-24-2005 08:42:46
I have pulled 3 seasons with my 3 3/4 pistons, no problems.. does an excellant job with a 2-16's also....
deenw
01-23-2005 17:06:41
thanks for the input guys i had thought about getting a 550 crank cause the rod journals are bigger but didnt know if the rods were same length as 66 or not..or if the mains were same or not...not looking for lots of rpms or anything just pulling antique class 3 1/2 mph against allis's in the 3000 and 3500 lb class...those combine motors are hard to beat..cant out hp them so i figurd decent hp and some good tires and perhaps better balance tricks..thanks again
770
01-23-2005 15:48:59
I was told the same thing with my 77. Been pulling it with no problems....Also know of a few 66"s up here with the 3-3/4 kit in them. Of course this IS just my opinion....
cobroller
01-23-2005 14:34:25
I wouldn"t be afraid of it myself. The crankshafts are steel forgings and the pistons are going to be lighter than the original cast iron ones.
