Barker's article in Hart Parr Oliver Collector
Chad (IA)
01-18-2005 18:15:31
I got the Hart Parr Oliver Collector today and enjoyed all the pictures and reading Dean's article about the "2004 Century of Tractor Power Show". I also have a question for Dean or VADAVE about their front tire size on your 1655 Diesels. I switched from a narrow to a wide front this past summer and need something better looking than the 6.5 x 16 that I have now. I'm thinking 9.5X15 4 ribs are what I need. I have two goals over the next 2 years (1) to restore my 1655 D to the point where I can replace VADAVE's with it on my screen saver; and (2) purchase another 1655 D with High Speed and have it ready for the 2nd annual CVEC tractor ride in Charles City, IA in 2006.
dwm
01-19-2005 19:11:02
 Re: Barker's article in Hart Parr Oliver Collector in reply to Chad (IA), 01-18-2005 18:15:31
I was at the Charles City show. Also, believe I've seen your tractor in IA, close to the tree nursery, right? FYI on tire size, I bought a new 1655 D years ago and it came with 11L-15 tri-rib Good Years on the front, 16.9-34 on the rear. I know some did come with the 9.5L-15 fronts.
Chad (IA)
01-20-2005 20:21:30
 Re: Barker's article in Hart Parr Oliver Collector in reply to dwm, 01-19-2005 19:11:02
Yes, In Ankeny. I think I will go with 9.5*15 and 9.5*16 on the high speed.
VADAVE
01-18-2005 18:46:35
Does look kinda nice--I have it as a screen saver too.
Tire size: Fronts are 9.5 X 15 rears are 18.4 X 34
This will surprise you, the paint is John Deere green. I laid one of the old panels beside a John Deere and couldn't tell the difference so that's what I went with.
One thing I plan to change is the step. I'm not exactly tall at 5' 6" and it's a bit of a step so I'm going to add two level step similar to what someone put on my 1855. I know I haven't posted that one, it could use a paint job, among other things.
Dale in IN
01-23-2005 09:09:58
 Re: Barker's article in Hart Parr Oliver Collector in reply to VADAVE, 01-18-2005 18:46:35
VADAVE:
I too am short plus back trouble and a bad hip. I took a piece if 2 in channel iron and bent it at a 90 degree angle and placed a flat plate on it. Then I ruffed it with the welder so as not to be to slick. I bolted this in front of the step on a 1600. It sure makes a difference when you only have to step up half that distance on the first step. I bolted it to the engine frame that already had the holes drilled and tapped for mounting impliments. As far as the green paint I painted this step with JD green as that was what I had on hand at the time. There is a slight difference but you have to look twice to tell. I have sense repainted the rear end housing and the 3Pt and a found what was called New Oliver green at a local farm store. Off hand I think it is made by Van Sickle. It was about half the price that the Oliver dealer charges. I dont know how it will hold up but I guess time will tell.
J. Schwiebert
01-18-2005 19:18:57
We had a guy with a 1750 and he added a second step so his wife could drive it. He make the step so it would swing kind of like the orignal 1800 steps. I had a buddie who pained his Oliver with 2 coats of Deere paint, why he had a connection less money then the third coat he used Oliver green.
VADAVE
01-19-2005 04:25:08
 Re: Barker's article in Hart Parr Oliver Collector in reply to J. Schwiebert, 01-18-2005 19:18:57
The paint listed as Oliver Green (off NAPA or Agri Supply shelf) is just too dark. It's way darker then Meadow Green only thing I could figure it was for older tractors. When I compared John Deere to Meadow Green I could tell the difference, doesn't mean there isn't some.
Doug S
01-29-2005 07:09:45
 Re: Barker's article in Hart Parr Oliver Collector in reply to VADAVE, 01-19-2005 04:25:08
There are three different Oliver green formulas from NAPA. About a year ago, NAPA went to a line called Crossfire. WHAT A DIFFERENCE. I have done two tractors and a baler with the new formula. Color is different from before, and on the baler, was an exact match.
