Looking for carb kit used on 99, 1650, 1655 1800
John (MO)
01-13-2005 12:08:06
The carb kit number is 778-506, it's for Marvel-Schebler carbs. This kit is suppose to have needle valves that many other kits don't have.
John (MO)
01-13-2005 14:44:12
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to John (MO), 01-13-2005 12:08:06
I wish I knew who's part # it was. I got the number from a guy out in California. Gosh his kit was high, and I was hoping to do better.
Jerry from East Iowa
01-13-2005 14:59:14
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to John (MO), 01-13-2005 14:44:12
Hi again, What I am able to get is what they call a Basic Repair Kit. It consists of throttle shaft, needle + seat, float lever pin, and gasket set. This kit is for M.S. carb #TSX 807 or tractor manufacture #104726AS. The price for this kit is $20.00 Plus shipping. I don't know where you're at but I would have to say it would amount to around $6 or $7 bucks. Let me know by e-mail at [email protected] or call me. Thanks, :) Jerry Jerry's Tractor Repair Holy Cross, Iowa 563-552-1615 or 563-590-1973
John (MO)
01-14-2005 07:01:24
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to Jerry from East Iowa, 01-13-2005 14:59:14
Thanks Jerry, those basic carb kits don't have the needle valves I need in them. I was hoping someone more local than California could get, or at least reconized this more complete kit. I kind of hate to have to deal with someone half a country a way, just in case this kit still doesn't have the needed parts.
01-14-2005 10:20:32
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to John (MO), 01-14-2005 07:01:24
Hi, again The needle and seat are in this kit. I can double check if you want. Just in case we are having a translation problem, the needle valve is the needle and seat. The only note on this carb kit is this kit has a solid needle not viton tipped.(ie. just like original) Thanks, :) Jerry Jerry's Tractor Repair Holy Cross, Iowa 563-552-1615 or 563-590-1973
John (MO)
01-14-2005 11:53:59
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to Jerry from East Iowa, 01-14-2005 10:20:32
Jerry, what I really need is a kit with the main adjusting needle and seat and also the idle jet.
01-14-2005 14:07:26
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to John (MO), 01-14-2005 11:53:59
Hi, again Why don't you let me see what I can track down?
So what you need is a load screw and a idle mixture screw, right? Any thing else that you can think of now that we are all on the same page? I won't be able to find out much before monday.
Hope that's OK. Thanks and have a good weekend. :) Jerry
01-17-2005 10:53:23
 Re: Looking for carb kit used on 99, 1650, 1655 1 in reply to Jerry from East Iowa, 01-14-2005 14:07:26
Hi, again I have run into dead ends so far. Why do you need thse extra parts?( broke, missing,etc??) 99% of the time you don't need these. Used carb to rebuild might be better answer. Can try and locate one of those for you. If you don't mind me asking what was the guy in CA trying to soak you for $ wise?
Thanks again, :) Jerry
Holy Cross, Iowa
01-13-2005 14:18:34
Hi, was wondering where that # came from? (Napa, Carquest, etc) I will see what I can find and price and I will get back to you. Thanks, :) Jerry Jerry's Tractor Repair Holy Cross , Iowa 563-552-1615 or 563-590-1973
