need help with fuel and temp gauges
chas
01-11-2005 21:05:38
I am trying to get these working on our 770. The fuel sender appears to work, as the ohms change with the movement of the float. The gauge goes from E to F when the key is on and hooked to sender. Stays on E when unhooked. It goes to F when wire is grounded to frame. Any ideas? How do I check the temp gauge? Thanks
J. Schwiebert
01-12-2005 07:25:47
 Re: need help with fuel and temp gauges in reply to chas, 01-11-2005 21:05:38
The temp gauge works on resistance too. If you use the fuel gauge sending unit as a variable resistor and hook it to the temp. gauge instead of the temperature sender, when you move the arm the resistance changes and the temp gauge should then move from cold to hot. Questions?
Jerry from East Iowa
01-12-2005 05:51:17
Hi, Sounds to me like your gauge is more than likely working.(The only way to know for sure is to hook it up to a variable resistor gauge tester)
Sounds to me like your wiring is seeking ground on you. Try eliminating the harness with a jump wire after unhooking the old wire, hook straight from gauge to sender. Any questions please e-mail me at [email protected] Thanks, :) Jerry Jerry's Tractor Repair Holy Cross , Iowa 563-5521615 or 563-590-1973
