OK - need an expert - I have an Iseki White 2-75 - like it a lot - late model ('88 I think).... I have had a PTO problem for several years now - took it to the dealer once and he charged $300 to adjust the controls (which I told him wasn't the problem) and said it was cured - ANYWAY this is what it does - any time of year when you first start the tractor if you throw the PTO in gear it starts fine, never slips and will kill the tractor if overloaded, BUT once the tractor has been driven a couple of miles or is warm this is what happens: the PTO starts fine and doesn't slip for a while... then a couple of different scenarios takes place - scenario 1 - doing things like sickle mowing - i will shut it off - turn it on several times - then all of a sudden it will decide not to start - scenario 2 - might be a better help - i hook it to a silage cutter and feed baled hay into it to grind it up for the horse and calves - if i feed an extra large piece of hay in sometimes it will pull the tractor down and keep going BUT sometimes the tractor will start to work, slow down a few RPMs, then all of a sudden the PTO will just stop and the tractor will be running - not working at all After both of these scenarios if you then go and start or stop the PTO - nothing - the only way it ever start again is to shut the tractor off - wait a few hours until it all cools then start again - The hydraulic fluid is always full - i changed it and the $175 filter this year - didn't help - the tractor is MFWD and has a loader - never have any trouble with anything hydraulic..... I have adjusted the feathering and control knobs - I have the service manual and took the PTO controller box off the top of the transmission and inspected it all and checked to make sure the orifice is clean like it says in the manual (all looks good) I don't have all the pressure guages and homemade steel templates and connections to do the startup pressure checks.... these are my ideas so far... do you think it might be the spring that is in the controller box and it just gets weak after it gets warm? this is my number one guess since if it was a bad o ring somewhere it would still act up when it is cold and wouldn't always go back to where it is supposed to be when the tractor cools.... What else should I check or replace it acts up with light loads (emptying silage wagons, sprayer pump, sickle mower or heavy loads - and the strange thing is usually if the PTO starts it will pull the tractor right down - but sometimes it decides it just doesn't want to start
