Valve depth in 1855 diesel head??
JC(WI)
01-10-2005 22:14:37
The manual I have has lots of info on valves on 1855 but does not say a word about dimension of protruion, flush or recessed into head. What is the optimum dimension here? Mine are recessed.
I was also surprised to see that the head doesn't have harden seat inserts or valve rotaters.
I also read in the manual that the gas and diesel engines had seals on the intake valves, then it went on to say that the gasoline used perfect circle seals. My head does not have any.
Thanks for info you guys can give to help me out here, JC
Wrenchbender
01-11-2005 05:18:10
 Re: Valve depth in 1855 diesel head?? in reply to JC(WI), 01-10-2005 22:14:37
JC, I think the Perfect Circle seals were used on only the intake of the gas engines. The diesel intake used a square ring that slides on the valve stem.
We had a tool to cut a land on the guide so that a P-C seal would fit on the diesel. We put seals on intake and exhaust both. WB.
george md
01-10-2005 23:01:22
JC, If my AERA cyl head manual is correct ,
int--.014 to.029 Protrusion
exh --.026 to .041 Protrusion head thickness new 4.500 to 4.505
minimum 4.470 george
J. Schwiebert
01-11-2005 04:09:13
 Re: Valve depth in 1855 diesel head?? in reply to george md, 01-10-2005 23:01:22
George: The dimmension are correct. However they are recessed in the head. Oliver also sent two bulletins out the first one did not have it correct. You want a copy send me an address and I will sent it to you. Put inserts in the head set them to specs and they start better and run good. On the valve seals you are not comparing apples to apples. Gas engines pull a vacuum. Turbocharged diesels do not. However you still need to maintain correct stem to guide clearance. Questions?
J. Schwiebert
01-11-2005 06:28:56
 Re: Valve depth in 1855 diesel head?? in reply to J. Schwiebert, 01-11-2005 04:09:13
George: i owe you one. They do protrude. I just double checked Sorry i appoligize. John
JC(WI)
01-11-2005 09:38:47
 Re: Valve depth in 1855 diesel head?? in reply to J. Schwiebert, 01-11-2005 06:28:56
Sounds like this 1855 head needs new seat inserts cut in and a valve job done to it. These valves are sitting in the head below the surface. And I was told that this engine was totally rebuilt when I bought the outfit. I haven't put that many hours on it yet. No. 5 cyl. had a leaking ex. valve and both seat and valve are pitted. this is the cyl. that I figure I am having trouble with for antifreeze problem. Think I will just touch up the valves for now and see if cutting the sleeve lands and shimming sleeves will stop the antifreeze problem. Thanks guys for info. Jerry
J. Schwiebert
01-11-2005 18:11:55
 Re: Valve depth in 1855 diesel head?? in reply to JC(WI), 01-11-2005 09:38:47
George has given you very good advice. It is money well spend. You will probably pick up 50-60 psi of compression. When they taught me how to rebuild the heads I did mostly did Oliver and Deere heads. Both dealers were happy on how they started. By luck my son & his pardner bough one of those Deeres about 8 years later. It is our best starting tractor.
george md
01-11-2005 17:07:03
JC,
If that engine is like JD and 400 Cummins ,when
the valves are too low in the head the engine will
be hard to start on cool or cold days . Being too
deep in the head lowers the compression . Many years ago I did the engine in a 450 JD
crawler , fellow that worked for me didn't check
the valve recession , we assembled it , sent it home
,and it would not start first time in the morning
on a 50 deg day. Thought about it , went took head off and put seats in it ,problem went away.
george
JC(WI)
01-11-2005 21:31:19
 Re: Valve depth in 1855 diesel head?? in reply to george md, 01-11-2005 17:07:03
Thanks for advice. George, Thats pretty nice work you did on that manifold. What was the rod you used with your torch? OK back to head/valves questions. What are the best valve seats available for this 1855 head? While it gets refurbished, is there anything to make this head better? Bigger valves? bronze guides? Or is it good enoughwith the origional specs? WHile I am asking all these questions, I pulled 5 of the injectors out and they came fairly easy, but the 6th one does not want to come out. I am down to the point of beating it out from delow. Any miracles here? Thanks again Jerry
george md
01-12-2005 16:28:34
 Re: Valve depth in 1855 diesel head?? in reply to JC(WI), 01-11-2005 21:31:19
Jerry, Thanks for the compliment, The rod is made of
cast iron . Being cast iron , it has basically
the same properties as the base material that
you are trying to weld .It expands and contracts
at that same rate therefore doesn't pull away
with temperature changes of manifolds like
arc weld does.
george
J. Schwiebert
01-12-2005 04:08:59
A good alloy seat works well. I can send you a copy of the bulletin if you want details. The intake seat will need to be on the thin side because of the slanted ports,otherwise you run the risk of not having any metal behind it. No doubt the seal has failed on the injector you can not get out. Make sure you use new seals when going back together. Questions?
george md
01-11-2005 09:27:23
John,
Accepted , glad we got it sorted out before we left him totally bewildered .:-)
Check out to pict's , I started tinkering with another waukesha manifold , 6MZA downdraft , somewhat of a resurection .
Also web site -- http://wwwgeorgemillermachine.com
george
