HYDRAULIC OIL IN 77
BULLDOG
01-10-2005 14:33:27
HEY GUYS. I HAVE 9 FARMALLS AND JUST PURCHASED THIS 77 RC. THE HYDRAULIC OIL OF CHOICE ON THESE FARALLS IS THE IH HY-TRAN. THE HYDRALIC PUMP ON THE 77 MAXES OUT AT 1200 PSI WHICH SEEMS REAL GOOD. WILL IT HURT THE OLIVER SYSTEM TO CHANGE IT OVER TO THE HYTRAN SO I DO NOT HAVE TO BE CONCERNED WITH CROSS CONTAMINATION WHEN ATTACHED TO VARIOUS CYLINDERS?
THANKS
Jerry from East Iowa
01-10-2005 17:17:12
 Re: HYDRAULIC OIL IN 77 in reply to BULLDOG, 01-10-2005 14:33:27
Hi, There is no reason why it won't. Ive done it numerous times before without adverse affects. Everybody says that their hydraulic oil is the bomb, and everybody elses is crap. makes you wonder how that is possible. When New Holland first came out with hydro skid-steers they called for using nothing but dextron. Then all of a sudden with no change to the hydros they called for nothing but universal hydraulic oil, and if you had to change oil they recommended complete system drain and switched to hydraulic oil.That being said, my opinion is you'll be OK. Thanks, :) Jerry Jerry's Tractor Repair Holy Cross , Iowa 563-552-1615 or cell#563-590-1973
ejr
01-10-2005 16:09:27
Thats what I use in mine.Even use it the transmission's.
