hey J Schweibert
luther
01-09-2005 17:13:18
Sometime back we talked about 105 hydraulics and you asked what kind of valve I am using on my wobble stick, it is a cross/BA valve currently on our 1850. The instructions to that valve say something about removing a plug and putting it in a different opening to switch the valve to closed center which you claim some valves will creep, hopefully this is not one of those? If it is, what brand do you recommend? I have to buy different mounting brackets for the white the oliver ones won't work. (darn) Thanks for your time once again.
J. Schwiebert
01-10-2005 04:28:04
 Re: hey J Schweibert in reply to luther, 01-09-2005 17:13:18
Luther: I was looking for your phone number this morning and did not find it. How often are you going to use or cycle this loader. All spools have leakage, that is what lubricates them. The better valves those that cycle many timesa day have internal ant-drift cartridges. If you use the loader every day and let it down when you are done you will be O. K. If not put a ball valve in the inlet line. Questions, give me a call. J. S.
luther
01-10-2005 17:03:30
 Re: hey J Schweibert in reply to J. Schwiebert, 01-10-2005 04:28:04
Thanks J. When not in use we almost always put the valve on float to relieve all pressure. Very seldom does the loader stay suspended even over night. When I get that far mounting it if I have trouble I'll get back to you for more help. Always appreciate the help. Thanks.
