pistons and sleeves question
Tracy Redd
01-08-2005 21:09:28
I have Oliver 880 standard 1959. I am thinking about put 3 7/8 pistons in it and i found a 3 7/8 pistons and sleeves kits from Korves Oliver. The pistons has a high dome. Will it work on orignal heads or i have to get another head?
Thanks
Tracy
cobroller
01-08-2005 21:26:36
 Re: pistons and sleeves question in reply to Tracy Redd, 01-08-2005 21:09:28
Will work with original head
rooster
01-08-2005 22:06:50
 Re: pistons and sleeves question in reply to cobroller, 01-08-2005 21:26:36
I believe you need valve rotaters when you run high dome pistons otherwise the valves will burn.
Don-Wi
01-09-2005 21:36:18
 Re: pistons and sleeves question in reply to rooster, 01-08-2005 22:06:50
Also go with LP valves. They stand up to the heat better. 2 exhaust valves in my 1600's engine were burnt pretty bad. Intake were ok, so i went with all new LP exhaust valves, reccommended by our Oliver/White dealer now gone Massey.
Donovan from Wisconsin
