Oliver transmission oil
oliverdave
01-07-2005 06:14:50
What kind of oil should I put in a Oliver 550 transmission and rearend? And what will the hydralic block take?.How do I drain the hydralic block?
RockinB
01-07-2005 11:25:11
 Re: Oliver transmission oil in reply to oliverdave, 01-07-2005 06:14:50
The service manual will explain the pump out procedure for the hydraulic.
J. Schwiebert
01-07-2005 06:40:11
80-90 Gear oil will work fine. Look underneath the tractor. There is more than one drain plug. You will need to remove all of them and drain all the compartments. The check plug is by the PYO shaft in the back. Buy the oil in a 5 gallon pail as will take all but about one quart if i remember correctly. The hydraulic oil needs to be pumped out. Change the filter and breathers on the hydraulic as well as the final drive housing. Contray to what some will tell you but a 10W-30 API classified motor oil for a gas engine will give good service. Questions?
oliverdave
01-07-2005 13:59:30
 Re: Oliver transmission oil in reply to J. Schwiebert, 01-07-2005 06:40:11
Where is the filters for the hydraulic block ?
J. Schwiebert
01-07-2005 17:07:29
 Re: Oliver transmission oil in reply to oliverdave, 01-07-2005 13:59:30
Does your hydraulic have a valve for operating a remote cylinder? There is only one filter. It is inside the cast housing toward the front of the hydraulic unit. It takes a 1-11/16 wrench. Part number used to be 100476AS. Questions?
oliverdave
01-08-2005 07:18:34
 Re: Oliver transmission oil in reply to J. Schwiebert, 01-07-2005 17:07:29
It dosn't have the valve for a remote cylinder,but has plugs in the block that could be for a valve.Where can I get a filter for that?
RockinB
01-07-2005 15:08:42
It is in the round can that protrudes horizontaly from the front of the hydraulic unit. I would stongly suggest you get a manual.
