570D crankshaft needed
H.B.Hutchens
01-06-2005 17:22:22
A friend of mine is in need of a 570D crankshaft.If anyone has one for sale please e mail a contact number to me and I will pass it on since he dosen't have a computer. Your assistance is appreciated. Thanks . H.B.
H.B. Hutchens
01-08-2005 17:23:58
 Re: 570D crankshaft needed in reply to H.B.Hutchens, 01-06-2005 17:22:22
Thanks for the replys, will see Vernon in a couple of days and see if he has any idea of sizes. Another question, who made the 570D engine, was on the BUDA site and found a 570D overhaul kits, are these by chance the same engine are or they the same as olivers. Again Thanks. H.B.
J. Schwiebert
01-08-2005 19:35:38
 Re: 570D crankshaft needed in reply to H.B. Hutchens, 01-08-2005 17:23:58
The reason you were asked about sizes is the straight 570 from the factory has a DD-298 Hercules. The 570 Super has a DD339 H Hercules. H being the code for heavier crankshaft. Also if your engine is a replacement Hercules for some reason it make have adifferent bearing size than either of the two above mentioned engines.
moleman
01-06-2005 18:32:28
Measure it like Phil said and email me. I have one that is a fresh machine shop turned crank with new matching bearings. Hopefully it will match his. I do have a good block and some other parts also.
P Heisey-Harleysville,PA
01-06-2005 17:28:14
H B Hutchens,
The 570D crankshafts are NOT all the same. Be sure you know the rod and crank journel sizes that your friend needs.
Phil Heisey 215-256-8651 FAX 215-256-1203
