550 Final Drives?
D.Miller
01-06-2005 17:14:52
When removing the final drives from a 550 is it necessary to unfasten anything on the inside of the housing,I have removed the six 1/2" bolts and the one large bolt located at the bottom of the housing yet I have had no luck getting the final drive to separate from the center housing.
J. Schwiebert
01-07-2005 02:50:17
 Re: 550 Final Drives? in reply to D.Miller, 01-06-2005 17:14:52
You did take the cover off and remove the snap rings? Also I would get two long bolts or pieces of ready rod at least 6-8 inches long insert them 180 degrees across from each other to slide the axle housing on when removing them. I have no idea if this is what you are doing, but if you are going to support the unit to work on something in there it may be easier to remove the out bearing cap slide the axle out and that way the axle housing(s) will help support the tractor .
KENT
01-06-2005 18:51:24
ARE YOU TALKING ABOUT THE AXLE HOUSINGS?---IF SO, I PUT A SMALL HYDRAULIC JACK IN BETWEEN THEM AND JACK THEM APART---THEY HAVE WIDE SEALS ON THEM THAT MAKE THEM HARD TO BREAK LOOSE---HOPE THIS HELPS--MY EMAIL IS OPEN IF I YOU NEED MORE INFORMATION
