Oliver Year Around cab pictures for Mitchell
TP from Central
01-04-2005 15:22:51
third party image
I just got the tractor two months ago, so these are some quick ones. I plain on taking off the cab soon so I can fix some leaks/repaint it so I can get some more detailed ones if you like. The year around is on an 1850 Diesel.
svehll
01-05-2005 11:11:40
 Re: Oliver Year Around cab pictures for Mitchell in reply to TP from Central PA, 01-04-2005 15:22:51
I have a cab on a 1850 and i am wanted to put ac in it. Does ant one know how to installed the ac compressor on a 1850 or were you installed. thank
josh the oliver man
01-04-2005 16:41:32
 Re: Oliver super 88 pulling motor in reply to TP from Central PA, 01-04-2005 15:22:51
i have a puller that builds up alot of heat i can only pull one class cause it gets to hot,does any one know how to get the heat away?
any help would be great. thanks
A.P.
01-05-2005 09:29:32
 Re: Oliver super 88 pulling motor in reply to josh the oliver man, 01-04-2005 16:41:32
Are you running a dry block and/or a dry head (no coolant in one or the other)? What engine are you running and how big (cubes & horsepower)is it? If you are running a big engine with some coolant, you might want to consider an electric driven water pump and fan to cool the engine? More information should help find a solution.
TP from Central PA
01-04-2005 15:23:50
 Another one in reply to TP from Central PA, 01-04-2005 15:22:51
third party image
TP from Central PA
01-04-2005 15:24:35
 Re: And another in reply to TP from Central PA, 01-04-2005 15:23:50
third party image
TP from Central PA
01-04-2005 15:25:19
 Last one...... in reply to TP from Central PA, 01-04-2005 15:24:35
third party image
