doing aoliver 77 for pulling
chot
01-02-2005 07:02:15
i am doing 77 for pulling i can pull 3trd gear in the 45/5500 class i wood like more power the 77 is stock wood like to put about $ 3000.00 in motor how much power can i get for that money and where in pa ny thanks chot
WFE
01-02-2005 09:42:46
 Re: doing aoliver 77 for pulling in reply to chot, 01-02-2005 07:02:15
You can search the archives of this site, as others in the past have done just what you want to do. There are several options, and $3000 should do plenty. How much hp are you looking for? You can put 770 sleeves and pistons in the 77 block to boost cubic inches. Flat top pistons are fine since you can shave the head to boost compression for significant power gains. Crank journals are smaller, so you have to use 77 bearings. Larger valves are a must, and you can go Oliver (770) or go automotive and have a machine shop do the head for you to make sure all the seat and recess geometry is correct. More air flow means more fuel can be burned, so a bigger carb will also be in order. A manifold and carb from a 1550/1600 can be used, or there are specialty carb shops that can customize a carb for your exact motor modifications. Run maximum rpms that your classes will allow, as Olivers develop power with rpms. 2500 rpm is a good range. Of course there's always stroking the crankshaft and using any number of combinations of rods and pistons. Good luck with your project, and I hope others post their secrets so I can learn too...
