1650 Diesel Rebuild
Bacman48
12-30-2004 20:03:12
I am doing a rebuild on the 283 indirect diesel engine. Do I need new rod bolts & pin bushings as in the 310 diesel? Thank You.
Adam Suess
12-31-2004 17:45:05
 Re: 1650 Diesel Rebuild in reply to Bacman48, 12-30-2004 20:03:12
Put new bushings in. They were a problem in these engiens unless there already switched to the one peice bushing. Even then I'd put new ones in. Usially the 1650 will knock when they get bad where as a 310 will throw a rod when they get bad. Even in a 1650 if left go it can cause engine failier. good luck
WFE
12-31-2004 06:14:56
Likely not rod bolts, but definitely pin bushings. The main reasons for replacing them on the 310 motors are that the original 6 point capscrews used proved to be one of the primary culprits for the initially high failure rate of these engines. The 1650s had no such trouble. We're also talking lower displacement and power rating on 1650s. However, professional engine rebuilders, as a rule, always use new rod cap hardware in a rebuild.
J. Schwiebert
12-31-2004 05:12:21
Pin bushings is a very good idea. If I remember correctly the 1650 diesels with a Lanova head have the same rods as the 283 cubic inch 1800 engines which means they use a different rod. They use bolts and nuts while the 310 engines use capscrews. I will check that out over the weekend.Questions?
Leob
12-31-2004 03:17:49
As far as I know, there were no problems with that particular engine. That was a very good engine, even when "not" properly maintained.
