1755 Clutch/Trans Questions
PaMike
12-29-2004 18:29:11
I have two questions
1-When I use the tractor for loader work I often am in a forward gear, then I will push in the clutch and coast backward. When I do this a sound comes out of the clutch area that sounds like a V belt slipping on a pully. My guess is the clutch isnt disengaging the whole way so its slipping on the pressure plate?
2-When the tractor is in the low set of the transmission it is difficult to get it out of gear and into another. You usually have to just slide it out of gear as the tractor is coasting to a stop.Putting it in under helps, put doesnt solve it. The upper range of the tranny works much better...
Thanks
DONOL60
12-30-2004 19:20:50
 Re: 1755 Clutch/Trans Questions in reply to PaMike, 12-29-2004 18:29:11
If the clutch is draging or not fully released ,when you shift into gear the gears will grind, if gears don/t grind when shiting from neutral to being in gear i would say the clutch is ok DON
bastar
12-29-2004 20:47:00
Think about what is happening when you are doing the operation as you describe. When the tractor is going forward the flywheel and clutch disc are turning in a clockwise direction viewed from the operators seat at the same speed. You push in the clutch pedal to release the pressure plate, tractor stops and clutch plate stops also, now tractor rolls backwards, powertrain is now driving the clutch disc through the input shaft. The clutch disc is now turning counterclockwise, or the opposite direction as the engine flywheel and pressure plate. The clutch disc can not be held firmly on the splines of the input shaft, or it will not move to the center between flywheel and pressure plate. You are getting some disc flutter as the two are rotating in opposite directions. That is the sound that you hear. The shifting charastic that you describe is kind of the nature of the design. The transmission has what is described as a "hopping Guard" to hold the gears in fully engaged position to handle the torque load that is applied. Anytime there is torque applied to the driving collar and the shifter it is difficult to get them uncoupled. What is happining is that you are trying to move the shifter over the hopping guard back to the neutral position. All tranmissions must have some kind of method of keeping the gears fully engaged.
PaMike
12-30-2004 09:15:05
 Re: 1755 Clutch/Trans Questions in reply to bastar, 12-29-2004 20:47:00
I realize the relative motion between the clutch, with one part moving one way and the other part the other. But since there is noise they must be touching when they turn opp directions. So the clutch must not be disengaging the whole way. Do you think the clutch would be on its last legs? Any place to look in at it?
As far as the transmission. Why would it be so much easier to get out of gear in high range? If I come to a complete stop in low range, with the clutch pushed in I cant get it out of gear. I have to let the clutch out so the tractor rolls slightly to pop it out of gear? This is normal?
Thanks for your help.
J. Schwiebert
12-30-2004 10:51:38
 Re: 1755 Clutch/Trans Questions in reply to PaMike, 12-30-2004 09:15:05
First of all Mr. Star has done an excellant job of explaining the details. Your clutch has ceramic pads. The pressure plate is cast iron as is the flywheel. I can not give you a logical explanation for part of this, but some of them make a noise when they are engaged, some do not, some make more noise than others. There are some factors here that you can check without too much time and effort. Remove the little inspection plate from the bellhousing and push down on the clutch petal. How far do the release levers move in before you feel resistance? You have not answered anyone on how much free travel you have. Another thing that might make it drag more in low is if the pilot bearing is starting to fail. Since the imput shaft is supported by the pilot bearing and it is in the flywheel it may tend to try to rotate the shaft more in low range since less effort (torque ) is requirred to do that than in high range. Does it make any difference which range of the over under shift you are in/ Also are you on level ground or is a little hilly. In my part of the country is does not vary a foot or so in a mile, but maybe not in your location/ Happy New Year.
PaMike
12-30-2004 14:24:25
 Re: 1755 Clutch/Trans Questions in reply to J. Schwiebert, 12-30-2004 10:51:38
I will have to check the tractor out tomorrow in the daylight to see how much free travelthe clutch pedal has. The transimission shifts smoother when in Under, but when I have the problem of it getting "stuck" it will do it in over or under. The more I think about it the more it sounnds like the clutch isnt releasing 100% so there is still a load on the trans, making it difficult to get out of gear.
PaMike
01-02-2005 08:37:12
 Re: 1755 Clutch/Trans Questions in reply to PaMike, 12-30-2004 14:24:25
I checked out the clutch free travel and its right with in spec. I tried to look in the access hole at the flywheel but all I can see is the flywheel...
Jerry from east Iowa
12-30-2004 10:44:54
Hi, again First of all the engine turns counter-clockwise not clockwise, I believe. That being said,what you are discribing is not normal. Normally these tractors shift fairly well considering they are 50+ year old technology.The reason it shifts harder in low range than high range has to do with the fact that there is more torque in the low side.(The same reason you usually pop start tractors in a high gear)It still boils down to the fact that your clutch is dragging, be it from linkage being out of adjustment, or clutch being warped, or dirt,or clutch starting to come apart.
Parts for these tractors are plentiful and cheap
(relatively speaking)and they are fairly easy to work on. Let me know if you have any questions or want to know prices, I willhelp you all I can. My e-mail address is [email protected] contact me there and I can give you my phone #
Thanks :) Jerry Jerry's Tractor Repair Holy Cross, Iowa
J. Schwiebert
12-30-2004 10:54:57
 Re: 1755 Clutch/Trans Questions in reply to Jerry from east Iowa, 12-30-2004 10:44:54
Jerry: I went through this when I changed from the engine side to the truck side. Engine mechanics look at the engine from the front looking back. It turns clockwise. I worked on the auxilary power side (PTO's and hydraulics) of the truck side They look toward the front so to them all engines turn counterclockwise. Happy New Year.
12-29-2004 19:38:41
 clutch problem in reply to PaMike, 12-29-2004 18:29:11
Hi It sounds to me as that your clutch is starting to come apart, that is if your linkage is correctly adjusted.If you have any questions please e-mail me at [email protected] Thanks
Kale
12-29-2004 19:07:32
Sounds like you have clutch problems. Check your free pedal, if you step down too far before you feel pressure, your clutch needs adjusted to have less free pedal. Another possibility could be a warped clutch disc. If it is warped, it will cause it to not disengage all the way. I would check the adjustment first as it is a pretty easy fix. Any oliver repair manual should walk you through it.
