WFE
12-29-2004 05:47:56
Re: 1755 D rebuild in reply to Randy-IA, 12-28-2004 20:08:23
Randy, sorry to hear about the loss of your friend. It is always more difficult jumping into the middle of a project like this, but with the right resources and if you have the time, you can do it. For what it's worth, here's what I would do in your situation: First, search the archives of this site by typing in 310, 310 Oliver, 310 Waukesha in the search box and print out past postings on this engine; they will help you. Then, contact the Floyd Co. Historical Society in Charles City, IA (641) 228-1099 and get a parts manual and a service manual for the tractor. The Oliver manuals are the best step-by-step references you'll find. And the parts manual will help you in returning all of the loose bolts and hardware to their correct locations, as each bolt is identified by size and proper location. As for the engine, I would err on the side of caution and use new sleeves and pistons. It is possible that the leak was only due to a bad seal, but one usually sees sleeves that are, at this age, brittle and may already have hairline cracks unless from electrolysis. If you see pitting on the sleeves, they should be replaced. Overhaul kits shouldn't be hard to find. AGCO has them, or Napa, Carquest, etc. and the larger auto parts stores can get the kits cheaper. Some considerations: use the one-piece wrist-pin bushings that come in the kit; not the split type. Second, order from AGCO a new set of 12 rod bolts (capscrews with 12 point head) and washers for the rod caps. Absolutely do not use the old ones. I would talk personally with the shop that ground the crank to verify rod and main sizes, and to make sure that the standard thrust main bearing is what they ground the crank to. I wouldn't dip the block. Just clean up the loose rust with a parts washer as best you can, make sure all the oil passages are blown clean via compressed air. If you have the block dipped, then you have to replace and size the cam bushings, which is extra work that is probably not necessary. Using the service manual and a micrometer, you can measure acceptable tolerances for the cam bushings and journals on the cam. 99% of the time they are just fine and show little wear. On 1755s, it is probably not as critical to have crank and system balanced, but do have the rods inspected, reconditioned, and balanced by a shop. Replace if necessary. The naked eye cannot tell if a rod is slightly bent. Specified head bolt torque in manual can be increased by 10%. While motor is out, other considerations are clutch and Over/Under. Replacing clutch, pilot and throw-out bearings, and O/U input and output shaft seals is a good job to do while the motor is out if they need it. If you have any questions, we'll be glad to help.
