2255 Rear engine mount proper adj.
todd08
12-27-2004 17:21:36
What is the correct way to set the rear engine mounts the wedge things? Have not found my service manual yet. Do
Greg D
12-29-2004 06:58:32
 Re: 2255 Rear engine mount proper adj. in reply to todd08, 12-27-2004 17:21:36
Just set my engine back in the frame. Now I have to get a dial indicator and get a copy of the service bulletin.
Greg Davis
2255TR
12-28-2004 08:12:49
I have never seen the procedure published in a service manual.WHITE released a bulletin to address the addition of a trunion mount support to the early 2255's. The procedure was listed in that bulletin.From memory,but have performed it numerous times it stated to install a dial indicator above over drive housing of the hydraul-shift (rear of the over/under) Turn square headed jack bolts on the adjuster blocks till .002-.003" of upward travel of hydraul-shift occur tighten down the two engine flywheel housing stud nuts and recheck dial indicator to ensure there was still .002-.003" movement.This will take load off the over/under and center the shafts.If this does not make any sense.I can try to explain further.
todd08
12-28-2004 08:22:34
 Re: 2255 Rear engine mount proper adj. in reply to 2255TR, 12-28-2004 08:12:49
Thanks a million! I understand.
