Oliver Row Crop 60; mid-40s
Randy Dodson
01-16-1998 03:34:39
anyone know where i can find an engine rebuild
kit for this tractor??
Ryan McPherson
02-03-1998 18:21:33
 Re: Oliver Row Crop 60; mid-40s in reply to Randy Dodson, 01-16-1998 03:34:39
: anyone know where i can find an engine rebuild : kit for this tractor??
The engine used in the Oliver 60 is a Waukesha enigne model '4-160', according to the Sealed Power parts catalog. Try asking for parts about that engine. I do know you can get gaskets, rod, main, and cam bearings as well as wrist pin bushings from Sealed Power. Hasting's makes sets of standard rings if your sleeves are still servicable. As far as front and rear main seals are concerned, just match your dimensions to that of Chicago Rawhide's and you shouldn't have any problems.
Pete Petrovic
01-16-1998 07:05:33
I couldn't find any pistons for mine (60 industrial) so I found a set of Continental pistons, .020 over, that looked real close and had the sleeves bored to fit the aluminum replacement pistons. Toyota 18r wrist pin bushings made the rods fit the pistons. The wrist pins had to be shortened slightly. The gasket set is the same a Waukesha 140 (I think) and bearings sets are still available, at least for the 6 cyl which is the same size as the 4 cyl. with an extra main bearing.
