marc smothers ( and others)-- WHY?
oleblu
12-17-2004 04:29:34
In the post below to VADAVE about his 2255, you stated to weld the three point arms closed. Are they a problem opening unexpectedly, or have you had some issues with them working properly? I have an 1800 and have never used anything on the 3 pt yet although a blade for snow and maybe a plow are in the future.
Wrenchbender
12-17-2004 06:25:49
 Re: marc smothers ( and others)-- WHY? in reply to oleblu, 12-17-2004 04:29:34
Shep is right about the wear on the pins and jaws, they get worn and you have alot of slop that lets the ball move around. Also the spring that holds the latch in place breaks or gets weak and that lets it open up.
In the past we would build up the lower half on the arm and replace the upper half, latch piece and pins. The upper jaw and latch got to be expensive to replace so some guys would just weld it shut. If you don't use the 3PH much or have a quick hitch then that works well.
I suggest that you put the ball in your arm and see how loose it fits. If it's fairly tight, I wouldn't worry too much. If it's loose, you can build up some of the parts to tighten things up. WB.
Shep VA
12-17-2004 05:03:31
Well at least what I have seen on my tractors is that the jaws wear at the pins and out in the jaw itself and it lets the balls pop out the sides when you are using it and it unexpectantly comes unhooked. It is really bad with a bale spear or a grader blade that swings on the three point a little.
So if the jaws themselves are in decent shape you can put a ball in there and weld the jaw shut on the end and stop it from letting the balls loose at least for a while. Then when they wear bad enough you have to take the jaw compleatly off and weld a ball and socket in the bottom half of the jaw and have a "normal" three point arm.
Oliver's three point system was great for hooking and unhooking impliments, just not very good for pulling hard, as they wear out fairly quickly.
This is just what I have seen.....
marc smothers
12-17-2004 18:50:22
 Re: marc smothers ( and others)-- WHY? in reply to Shep VA, 12-17-2004 05:03:31
My bad experience was towing the 8's down the road and going around a corner and having them pop open and leaning against the car going by.. We have 8 White and Olivers with the latches and they are fine. My 2255 was welded up and poorly done, so I welded them better and put quick coupler on it. If the balls and arms are good shape they will be fine if you don't abuse them. My 2255 must have been abused before I got it, and I do not believe Oliver should have used the setup in a Cat. 3 hitch. The quick coupler helps because it is supported by all three arms, although I have had them pop open even with the quick coupler... If any one needs new latches I have a couple new sets I got at an auction.. Merry Christmas, Marc
