According to my manual the Intake valves are set at .009-.011 and the exhaust are .015-.017. Here is the procedure from the book. "Proper vlave clearnace adjustment is part of correct valve timin. To take an accurate measurement of this clearance, the valve stem end and rocker arm contact button must make a good curved surface contact. If either surface has worn hollow, it is impossible to make an accurate check with a feeler gauge. Inspect these parts first and either rework them on a valve grinding machine, or replace them if the contacts are not satisfactory. Adjust the clearance when the engine is cold approximately 70� F. 1. Remove the cylinder head cover is installed. 2. With a 1-1/8 inch socket wrench and extension, crnk the engine over by hand until number one piston is nearing the top of its compression stroke: that is piston up and both valves closed. (it doesn't mention it but make sure the battery is disconnected) 3. Loosen the rocker arm lock nut over the push rod and insert a feeler gauge of the correct thickness in the gap between the rocker arm button and the valve stem end. 4. Turn the rocker arm adjusting screw either direction as required, with a screw driver, until the feeler gauge can just be moved in and out of the gap. 5. Tighten the lock nut and recheck the clearance. 6. Repeat the avove procedure for all cyliners: always loosening the lock nut, adjusting the screw, retightening the nut and finally checking again with the proper feeler gauge. Enjoy..... ..... .....
