Value of a 1600
steve metcalfe
12-13-2004 06:24:48
I recently came across a 1600 gas with a narrow front, good original shape. Comes with a Kewanee 10 ft. disc and harrow, and a 8 or 9 ft. flail mower. The guy wants to sell me everything as a package but I dont have any idea what its worth and is there anything I should look for on the tractor that were problems ? Thanks for your help Steve.
Dale in IN
12-13-2004 06:53:13
 Re: Value of a 1600 in reply to steve metcalfe, 12-13-2004 06:24:48
I just bought one in Sept that had a 20/20 hit and miss paint job. Engine starts easy and seem to be sound. I have just been into the trans. and differential and every thing in there looked good. The reason I went into these was because when I drained the trans. oil I found a spring that had went under a gear and flattened it out. It had came out of the gear shift lever. It was one of the centering springs for the lever. Also found pieces of the saftey starting switch, which had been crushed and a small piece of casting from part of the shift lever casting and one of the dowell pins that had been droped in from some ones carelessness. I paid $3500 for this one. It is a late 1963. It has new rear tires. One new rear rim and no fluid in them. A new seat and hydro shift. Also the fenders were rusted bad so they had put a set of aftermarket fuel tank fenders on it. They also had cut most of the wiring lose so I have no lights.
