Oliver Super 77 clutch trouble
Eric B
07-28-1999 11:43:09
My clutch recently decided to stop working. The pedal depresses normally, but the clutch won't disengage. How do I tell if the release bearing is the problem or if the disc is frozen to the flywheel due to moisture and inactivity? Can I investigate by pulling the bellhousing back or do I need to split the tractor to allow access? Any help would be greatly appreciated. The second to last time I used the tractor the clutch worked as good as new.
Dick in NW Ohio
07-29-1999 06:49:20
 Re: Oliver Super 77 clutch trouble in reply to Eric B, 07-28-1999 11:43:09
Eric; If it does not have a belt pully housing you can pull the power takeoff out the back, remove the drive shaft, slide the bellhousing back and remove the clutch. If it has the power takeoff you get the privilage of removing the engine. The Oliver 77 don't split like Fords to get to the clutch. Good Luck
