Button head grease fittings
Polk Crawler
12-10-2004 08:24:43
Found what I needed at JD dealer, replaces what is usually found on a grease gun.
Difference of opinion on what to pump in but imagine the 90W is ok if seals hold and don't let it all run out. On older rigs that might happen.
PC
ray Z.
12-10-2004 08:55:01
 Re: Button head grease fittings in reply to Polk Crawler, 12-10-2004 08:24:43
Yes, PC,
Use 90 or 140 wt, but use only the GL-1 grade which is a mineral oil and will not ruin your bronze bushings like the other gear oils will.
Good Luck, Ray
VADAVE
12-10-2004 17:15:06
 Re: Button head grease fittings in reply to ray Z., 12-10-2004 08:55:01
What about corn head grease?
I use that on the gears in the clean grain auger. It flows which egular grease won't do yet works in a grease gun real well.
