770 Chatter in Third Gear
John, Ohio
12-08-2004 17:49:11
I just rebuilt my transmission and differential in my 770. All went well. Except I notice in third gear I have a slight chatter noise. It also does not seem to detent in as deep in third gear and first gear as it does in the other gears. I don't notice the noise in first gear. I can't remember if these two are on the same shifter fork. Other than this, the operation was quite a success. I may take the hydraulic unit off to have a look later on. But the tractor is performing fine and working okay. Any opinions would be very appreciated. Thanks!
770
12-09-2004 13:21:16
 Re: 770 Chatter in Third Gear in reply to John, Ohio, 12-08-2004 17:49:11
Plenty of fluid, right??? I THINK 1 2 and 5 are on the same shaft but I can't remember. IT mannual would show the gears. Did you replace that counter gear??? Maybe the teth are worn different??? Just some ideas...
