Oliver 77 Rear End Ratio
RCP
12-05-2004 13:21:52
I always thought that the later model 77"s (ie disc brake tractors) had a lower speed rear end, but after looking at the parts manual it seems that the ratios were availble in either one. How can I tell what ratio a tractor has without taking it apart?
Thanks
Rich
bastar
12-06-2004 22:17:25
 Re: Oliver 77 Rear End Ratio in reply to RCP, 12-05-2004 13:21:52
The earliest production (first two years) were the fastest. Those tractors are between serial numbers 320001 & 325700. The last three digits in the serial number should be C-77. Tractors after Serial number 325701 were slowed down from a 1st gear speed of 2.63 to 2.45 and the digits after the dash should be C-77-D or C-2. There is a special low speed powertrain that has a 1st gear speed of 1.91. It is identified as C-77-C or C-5 in the last digits. The exception to the above is if you have a tractor with either a serial number with first two digits of 35 or 45, there is not any identification in the serial number for the powertrain.
RCP
12-08-2004 03:30:12
 Re: Oliver 77 Rear End Ratio in reply to bastar, 12-06-2004 22:17:25
Was the change in the ring and pinion or in the transmission gears?
ejr
12-05-2004 14:19:01
I believe it is on your serial no, plate in the code.Don't have a 77 operator manual but in my 770 book it tells different ratio and tire size speeds.
RCP
12-05-2004 13:28:35
By the way I need to slow my tractor down.
