need help with some tires
Pawel
12-05-2004 04:43:23
HI For my 1650 diesel I have 1 pressed steel and one cast iron center tire on the right and the left of the tractor. The cast iron is a removable hub, and the pressed steel is a fixed hub. The rim on the pressed steel is in much better shape than the rim on cast iron center. I don"t seem to be able to locate though another pressed stell rim and hub. Does anyone know (or have)any rims (or advice)
hanging around?
Thanks Pawel
Wrenchbender
12-06-2004 04:26:43
 Re: need help with some tires in reply to Pawel, 12-05-2004 04:43:23
Pawel, I don't know where you're located but I've got a set of 16.9-34 wheels from a 1650. They are the cast center type, I would sell the rim only or the whole wheel.
I'm in west central Indiana. WB
stroker88
12-05-2004 06:55:23
the hub should fasten to the axle with three u-bolts. and have a nine bolt pattern. i might have hubs. what is the axle diameter?
Farmer in the Dells (WI)
12-05-2004 05:19:21
You may want to try the pulling forum. I believe the pressed steel wheels are popular with that group. Don't forget to list your size when you post. Good luck.
