Help! I broke my Oliver 550!
Ray Z.
11-29-2004 05:39:29
I broke a shift fork ni my 550, I only have gears 6, 2, 5,and 4th. Does anyone know where I can get another shift fork and is this a commom problem?
Thank you, any input is appreciated!
Ray
jakej
12-01-2004 08:49:22
 Re: Help! I broke my Oliver 550! in reply to Ray Z., 11-29-2004 05:39:29
Had a similar problem with a Super 55, the previous owner failed to replace the 1/4 lock washers causing too much play and only 1/2 the gears to engage. As there are only 2 1/4" bolts holding each yoke these would these would be the place to looh.
RockinB
11-29-2004 08:22:53
Try Maibachs' in Creston, Ohio.The new ones are pricey,150.00 if I recall.Used maybe considerably less.I had one welded one time,just make sure the tines are aligned properly.The welding cost me 15.00.
Ray z.
11-29-2004 14:01:35
 Re: Help! I broke my Oliver 550! in reply to RockinB, 11-29-2004 08:22:53
DID THE WELD HOLD?, I THOUGHT THEY ARE HARDENED. I CONSIDERED WELDING, BUT I WAS NOT SURE....
RockinB
11-29-2004 19:33:20
 Re: Help! I broke my Oliver 550! in reply to Ray z., 11-29-2004 14:01:35
I used the tractor for a year or two after welding the fork,when sold it was still working.The weld was done by a fulltime welder in the strip mining industry,what type of rod he used,I have no idea.Once welded,ground and polished it was practicly undetectable.
KENT
11-29-2004 05:53:06
hi--i can help---my email is open---give me a shout
ray z.
12-02-2004 04:12:58
 Re: Help! I broke my Oliver 550! in reply to KENT, 11-29-2004 05:53:06
I found my problem the shift fork was broken (part # 1E1629) I welded it with the mig welder, now to install it and see how long it lasts.
I need to do some plowing this weekend.
Thanks for the input guys!
Ray
