Oliver Bull Dozer
nauticalwheeler
11-28-2004 16:57:44
Hello,
I am doing some research for a friend of mine. He is buying an Oliver Bull dozer and would like more information on it. Here are the specs that he gave me:
Oliver HG-35 (or HB)
Serial Number 12660
Motor: Gas #F6226856387
RFC141
Any information would be greatly appreciated.
Thanks, Jeff
J. Schwiebert
11-28-2004 17:54:27
 Re: Oliver Bull Dozer in reply to nauticalwheeler, 11-28-2004 16:57:44
You opened up a can of worms here that has all kind of information that really doe not match either of the two models below. You said HG which is a small crawler produced untill the midle of 1951. They had a 4 cylinder IX Hercules engine. The serial number does not match nor do the 2 numbers in the model number. The 2 numbers in the model number would be the center to center width of the tracks. There was no 35 inch. The engine model you gave is for a Continental F226 which was only used in a larger crawler about the size of a D2-Cat. That would be the model AG-6. The numbers after the model number or the serial number do not match either model. Can you post a picture?
nauticalwheeler
11-29-2004 04:22:19
 Re: Oliver Bull Dozer in reply to J. Schwiebert, 11-28-2004 17:54:27
It might be a combination....I will try and get a picture. I will also double check the numbers. I really appreciate all the info though.
Jeff
Ray Z.
11-29-2004 05:33:35
 Re: Oliver Bull Dozer in reply to nauticalwheeler, 11-29-2004 04:22:19
That sounds like a Terratrac HB-35, That company was bought out by Case, No Cletrac parts will fit.
Ray
Ray Z.
11-29-2004 08:10:42
 Re: Oliver Bull Dozer in reply to Ray Z., 11-29-2004 05:33:35
I,m sorry, it could be an Oliver model B crawler if those numbers are off the Heil dozer assembly. HB-35 is a Heil blade model number
Ray
