Shifting into 'low' range on a OC-6
Kurt Bangert
07-25-1999 19:15:00
I have just aquired a OC-6 crawler and can't seem to get it to shift into the lower range of gears. Is there a 'trick' to it or some common problem that makes the shift difficult?
Have had and operated lots of old tractors, this is my first Oliver.
JEFF
07-26-1999 06:46:27
 Re: Shifting into 'low' range on a OC-6 in reply to Kurt Bangert, 07-25-1999 19:15:00
IT SHIFTS JUST LIKE OTHER OLIVERS WITH THE SIX SPEED TRANNY.
WHEN ITS IN NEUTRAL(CENTER OF THE H PATTERN)JUST PUSH FORWARD OR PULL BACK TO ACCESS THE SECOND H PATTERN. HIGH RANGE HAS R2 6 4 3 LOW RANGE HAS R1 5 2 1
WHEN I GOT MINE THE BALL DETENTS WERE FROZE UP
WHICH MADE SHIFTING VERY DIFFICULT. WHEN IT'S
CLEANED UP AND LUBED THERE ISN'T A SMOOTHER SHIFTING TRANNY AROUND.
HOPE THIS HELPS JEFF
