Oliver 60 3 brush generator
wkeitel
11-25-2004 08:44:01
Can I remove the light switch. Ground the field wire that went to it, and use a twelve volt battery
Geoffrey in KS
11-27-2004 13:56:48
 Re: Oliver 60 3 brush generator in reply to wkeitel, 11-25-2004 08:44:01
Hi,
I see your wife is with Farm Collector. Are you from Topeka? I'm within 40 miles of there.
Geoffrey
W. Keitel
11-28-2004 17:39:36
 Re: Oliver 60 3 brush generator in reply to Geoffrey in KS, 11-27-2004 13:56:48
Yes we are from Holton, KS. about 30 to 35 miles north of Topeka.
Shawn Manck
11-26-2004 19:33:32
The simplest way to get your 3 brush generater working properly without the light switch is to use a voltage regulator(available from tractor supply) this will eliminate the need for the light switch and the cutout relay. This is just for the 6 volt system. If yo uare going to use the original 6 volt generator you should keep the rest of the tractor 6 volt. If not you will have to get a 12 volt generator or alternator, as well as change the coil and battery. hope this is helpful
W. Keitel
11-26-2004 20:58:00
 Re: Oliver 60 3 brush generator in reply to Shawn Manck, 11-26-2004 19:33:32
I don't think that a regulater will work for a generator that normally has a cut off with a field.
J.Schwiebert
11-25-2004 10:54:03
I forgot to ask you, are you increasing the speed of the generator/
J.Schwiebert
11-25-2004 10:05:08
How are you going to regulate the output? What are you using for a cut out?
wkeitel
11-25-2004 18:36:12
 Re: Oliver 60 3 brush generator in reply to J.Schwiebert, 11-25-2004 10:05:08
I was going to us the regulater with two post one coming from the armature to the regulater and from the regulater to the battery
J.Schwiebert
11-25-2004 20:20:12
 Re: Oliver 60 3 brush generator in reply to wkeitel, 11-25-2004 18:36:12
That is not a regulator. It is the cut out relay.
Output is controllef by the position of the third brush and the resistors in the light switch. Does it charge now> We are doing a troubleshooting for the Hart Parr Oliver magazine 2 issues from now, Would you like to be a test case and try out the information before hand?
tkeitel
11-26-2004 06:28:22
 Re: Oliver 60 3 brush generator in reply to J.Schwiebert, 11-25-2004 20:20:12
My wife wanted you to know that she has talked with the lady at Hart par magazine. My wife is with Farm Collector and Gas engine Magazine.
wkeitel
11-26-2004 06:22:42
I havn't put the generator back together yet. Will try today. See if I can get anything out of it. I don't have the light switch any more. Was going to try to make it work with out it. I probaly wouldn't be a very good test subject. But, I sure like the info.
J.Schwiebert
11-26-2004 07:27:09
 Re: Oliver 60 3 brush generator in reply to wkeitel, 11-26-2004 06:22:42
Do you know what a motor test of a generator is?You need to do that before you put it on the tractor. Nothing fancy required. Do you have an ohmmeter and a voltmeter? Go to hartparroliver.org and leave me a message or contact Becky. Her husband knows how to contact me. A 60 should work on 6 volts just fine.
W. Keitel
11-26-2004 12:45:29
 Re: Oliver 60 3 brush generator in reply to J.Schwiebert, 11-26-2004 07:27:09
I'm showing a charge on my generator. By using a drill and a volt meter. I polorized it with the batter charger. But, I show a neg. - charge with the tractor running. Started and running tractor on a 12 volt Battery, with out the generator hooked to it. still neg charge. going after 8 volt battery. hook up pos. or neg. ground. ???
J.Schwiebert
11-26-2004 14:07:14
 Re: Oliver 60 3 brush generator in reply to W. Keitel, 11-26-2004 12:45:29
How much voltage do you have? does your cut out work. It is positive ground. Did you cross the wire going to the moveable third brush? They must cross. Will the generator turn as a motor, I asked that before and if so how fast will it turn? Where did you complete the field circuit?
W. Keitel
11-26-2004 14:43:44
 Re: Oliver 60 3 brush generator in reply to J.Schwiebert, 11-26-2004 14:07:14
Yes ,it will turn as a motor. But, I show a Neg. on my volt meter.
J. Schwiebert
11-26-2004 15:15:47
 Re: Oliver 60 3 brush generator in reply to W. Keitel, 11-26-2004 14:43:44
Well how did you hook this up? You need 3 jumper cables. If you have the leads reversed on the two brushes it will also show negative.Did it turn fast or real slow? You need to be able to get both speeds. Send me a phone number Problems like this are a good challange.
W. Keitel
11-26-2004 21:10:01
 Re: Oliver 60 3 brush generator in reply to J. Schwiebert, 11-26-2004 15:15:47
No, I did not get two speeds. I don't think the cut out is working. I get a neg. on volt. or .04 But if I ground the field I get 9.0 to 11.O volts and it will pull the engine of the tractor. if I put it on the Battery. Show neg off the generator.
[email protected]
W. Keitel
11-26-2004 08:42:50
Yes, I have a volt meter. I'll work on getting it back together and working. That brush working off the field has to be adjusted? I'll try getting ahold of you threw Hart Parr. The lady my wife has talked to was Sherry.
wkeitel
11-25-2004 18:45:11
Could I use a voltage regulater with 3 post one for the armature, one for the field, other to the battery. No, I wasn't planning to change the speed of the generator. If I used a three post regulater, I might just use a 8 volt battery. I wasn't planing to worry about lights. Just try to get the battery to charge
