77 hyd capacity
BE IN MO.
11-23-2004 19:03:14
this is my first tractor project and I can't get my hyd. to work. I've checked in the manual for capacity of the unit and I've put in 2.5 gallons and it is still not touching the dipstick how much does it hold? Thanks
J. Schwiebert
11-24-2004 06:02:57
 Re: 77 hyd capacity in reply to BE IN MO., 11-23-2004 19:03:14
You did not say if you had a single or double unit, but 5 quart should have been good. The hydraulic unit will need to come off. Remember to remove the long PTO shaft first. Questions?
Mike (WA)
11-24-2004 08:15:59
 Re: 77 hyd capacity in reply to J. Schwiebert, 11-24-2004 06:02:57
How could he have put 2 1/2 gallons in the hydraulic unit already? It sounds like he may have the hydraulic and transmission/final fill points confused.
BE IN MO.
11-24-2004 12:37:49
 Re: 77 hyd capacity in reply to Mike (WA), 11-24-2004 08:15:59
maybe I do, I put the oil in this unit that is under the dash in front of the seat with a single lever coming out of it, two hyd. hoses come out of the right side (if you are in the seat)and go to the back with pioneer fittings on them.
BE IN MO
11-24-2004 06:25:37
I have a single unit. thanks for your input and I'm sure I'll have more questions.
old
11-23-2004 19:25:49
You may have a leak in the system or it was dry which isn't good. I looked in my manual and it doesn't say how much either. What part of MO are you in by the way. I have 3 77 also here in MO.
BE IN MO.
11-23-2004 19:32:01
 Re: 77 hyd capacity in reply to old, 11-23-2004 19:25:49
Northern MO. south of chilicothe.
old
11-23-2004 21:14:28
 Re: 77 hyd capacity in reply to BE IN MO., 11-23-2004 19:32:01
I'm at the lake of the ozarks. Hope your ready for snow you should get some tomorrow.
jim latson
11-06-2005 12:39:11
 Re: 77 hyd capacity in reply to old, 11-23-2004 21:14:28
1850 Oliver , Perkins di.
What is the lift capacity ???? lbs.
