JUST FOUND A 550 WITH A SHUTTLE SHIFT ???
KENT
11-19-2004 16:21:48
I JUST FOUND A 550 WITH A FORWARD-REVERSE LEVER AS WELL AS THE REGULAR GEAR SHIFT--ACCORDING TO THE SHIFT PATTERN, IT GIVES YOU 4 FORWARD & 4 REVERSE SPEEDS---MY PARTS BOOK DOESN'T SHOW THIS TRANSMISSION SETUP--- WAS THIS AN OPTION FROM OLIVER OR AFTERMARKET ADD-ON ??--IT ALSO HAD POWER STEERING--I'M TRYING TO LOCATE THE OWNER--IF I GET IT, I WILL PROBABLY PART IT OUT DUE TO IT'S CONDITION---ANY REPLIES WILL BE APPRECIATED
R Tanner
11-22-2004 05:56:37
 Re: JUST FOUND A 550 WITH A SHUTTLE SHIFT ??? in reply to KENT, 11-19-2004 16:21:48
Kent, it is a 2-44 sold by white but made by Oliver. You say you are parting it out? I need a steering gear box complete with the power steering motor mounted no top of it. Please reply if you are in a position to sell these items.
Thanks
R Tanner
KENT
11-22-2004 06:24:16
 Re: JUST FOUND A 550 WITH A SHUTTLE SHIFT ??? in reply to R Tanner, 11-22-2004 05:56:37
I'M WORKING ON FINDIND THE OWNER--IT MAY BE A WHILE---THANKS
Frank Dodson
11-19-2004 18:55:48
The description sounds as if is an industrial 550. In the mid 60's Oliver manufactured the 550 with a 4-speed shuttle and heavier hydraulics. The tractor usually was equiped with the model 588 loader and model 613 backhoe. I remember one of the selling points that the Oliver rep made was the short time it took this machine to dig a grave. My cousin was an Oliver dealer at the time and he sold some of these units but I don't think he sold any to cemeteries or undertakers.
Leob
11-19-2004 19:43:45
 Re: JUST FOUND A 550 WITH A SHUTTLE SHIFT ??? in reply to Frank Dodson, 11-19-2004 18:55:48
Sounds like it could be a White 2-44, an industrial vs. of the 550. Does it have a foot throttle?
