No oil going thru filter on 66??
Djt
11-14-2004 20:03:32
I noticed after running my 1953 66 that the oil filter was not at all warm, as it would be if hot engine oil was passing thru it. I worked it for awhile and engine was definately up to temperature. Pulled the oil filter off after I got it back in the garage and there was very little to no oil. Then did a oil change and installed a new filter and it still doesnt seem like oil is going thru it. Can I have something wrong, like a bypass that is stuck open not allowing the oil to pass thru the filter? I am running a NAPA #1700 gold filter.
Thanks
Larry from MD
11-15-2004 08:31:55
 Re: No oil going thru filter on 66?? in reply to Djt, 11-14-2004 20:03:32
The restrictor in the filter base is probably plugged.It is under the tube that sticks into the filter.
jld
11-15-2004 05:56:27
Had the same problem with 6 cyl 88d engine. Filter base and return hole in block were plugged with dirty oil and cotton-like stuff (probably from the old cotton filled filters). The engine still lubricates as ba stated, just no filtration thru the low psi by-pass system. Hopefully, the photo shows the plugged hole and the return passage depicted by a straw.
bastar
11-14-2004 23:05:20
The filtering system on the engines of that period are of the "bypass" type. A metered amount of oil is allowed to flow through the filter and is dumped into the crankcase after it is filtered. If you have oil pressure, your engine should be lubricated.
donol60
11-15-2004 07:56:53
 Re: No oil going thru filter on 66?? in reply to bastar, 11-14-2004 23:05:20
Is the oil tube still in the filter base? Sometimes this tube sticks in old filter and gets discarded,this also causes low oil pressure.
Djt
11-15-2004 16:57:09
 Re: No oil going thru filter on 66?? in reply to donol60, 11-15-2004 07:56:53
Yes, tube is there. It's about 1/4" in dia and approx. 2" long, right in the center of the base, right? This is my first Oliver...
Thanks
