550 diesel smokes black,. Help!
Green Farmer
11-13-2004 15:50:09
I have a 550 diesel with 2500 hours that has recently started to smoke black. Does not seem to have lost power and still starts good, but it sure stinks and is auful annoying. Any suggestions on where to start. Leaky injector maybe? Please help!
RAB
11-14-2004 23:26:10
 Re: 550 diesel smokes black,. Help! in reply to Green Farmer, 11-13-2004 15:50:09
Like JS says, we need more info. You need to tie it down a bit more at your end. Diagnoses from a distance are hard enough even with all the relevant information.
For instance, it could be an inlet cam lobe failed and valve not allowing enough clean air into the pot. Not very likely if you are the regular tappet setter, as you should notice things like that.
Try all the cheap (free?) fixes first. Look at the valve lash - a tight clearance could reduce compression enough, broken valve spring valve closing,but not tightly.
If you find it is only one cylinder that is smoking it sure makes it easier and cheaper to fix.
RAB
J. Schwiebert
11-14-2004 13:57:06
Just like with a gas engine, first thing to find out is one cylinder causing this or more than one. In othr words we need to look at what cylinder(s) is the culprit.
Green Farmer
11-14-2004 15:05:24
 Re: 550 diesel smokes black,. Help! in reply to J. Schwiebert, 11-14-2004 13:57:06
Today I changed fuel filters, cleaned the air cleaner, (was not too dirty), and then began to loosen each injection line one by one until the engine began to misfire. It did not seem to be on any particular cylinder. I mispoke on the original posting. Inside of exhaust pipe is very black, but smoke is kind of gray color. Thanks for your suggestions thus far.
mitchell hastings
11-13-2004 17:10:30
hi
any time a diesel smokes black it means that the engine isn't entirely burning the fuel that's being injected into the cylinders.
think simple..
it could be a clogged air filter, injection pump timming, low compression, or possibly an injector that has a bad tip. if it was an injector you would most likely notice a miss though.
