S88 Steering Wheel Removal
Nathan in MN
11-12-2004 15:32:30
How do I pull the steering wheel off of my Super 88? It"s in really bad shape (rubber falling off) and so I want to replace it. I pulled off the center cap and nut, and broke off the rubber around the center. But, there aren"t any holes to put a wheel puller on. So, how do I do this?
Thanks in advance for any help,
Nathan in MN
Ed Schulte
11-12-2004 19:30:01
 Re: S88 Steering Wheel Removal in reply to Nathan in MN, 11-12-2004 15:32:30
Remove steering knokle under dash and remove half moon key ,pull shaft out and put it under a press , I have did this several times and it works.
old
11-12-2004 18:18:52
Maybe a big gear puller and even then it can be fun, you might also heat it up some
donol60
11-12-2004 19:53:16
 Re: S88 Steering Wheel Removal in reply to old, 11-12-2004 18:18:52
A 3 arm gear puller and some fast heat works for me,after gear puller is good and tight hit head of screw with hammer.
