66 oliver block
rand
11-10-2004 18:33:06
was looking to put a 66 together to pull and was wanting to put 3 3/4 sleeves and pistons in..but the block is cracked between the cylinders so do i need a new one or will a head gasket seal on top?..the webbing in between the sleeves is cracked also..can i weld this for added strength and get by?..plan on running water and just pull div 2...nothing to major..thanks for any help and advice
Wes Dorhout
11-11-2004 14:31:53
 Re: 66 oliver block in reply to rand, 11-10-2004 18:33:06
I have a used block if interested. E-mail or call 712-324-2760
stroker88
11-10-2004 19:21:32
if it is just cracked on the top deck you should be ok. if it is cracked in the lower bore you will get coolant in the oil. the tough part about welding it is it will be hard to machine after wards.
