Timing a 1655
farmboy4918
11-10-2004 07:48:59
My brother inherited a gas 1655 and it needs a good tune-up. First: what is the spark plug setting>Second: which is set first, the point gap or the timing and what are the numbers for each? Third: Is there a dwell no. for the points?
Fourth: procedure--do you set the timing like the old cars with a timing light at the front or do you set no.1 cylinder to TDC along with a mark at the bell housing and then adust point gap? As you can tell it"s been a long time since I"ve tuned an old car! Thanks for your help!
dwm
11-11-2004 12:33:15
 Re: Timing a 1655 in reply to farmboy4918, 11-10-2004 07:48:59
First thing I would do is get an Operator's Manual. Check out/do a search on the Floyd County Historical Society in Iowa. They will have your manual. It will also have all these specs. I'll try to answer some. In the absence of a spec, I would try .030" gap on spark plugs, .025" on point gap. I would be surprised if the timing has been messed with. It's checked on the flywheel, not the front pulley. On the front of the bell housing where it meets the block, there should be a cover over a small inspection hole. Open this and you can see the front side of the flywheel. There is a lip on the flywheel and should be a paper sticky tape stuck on the lip marked off in degrees. I don't know the timing spec for a 1655, but this is where you can read the timing light. I would still verify number one on compression/TDC etc. and see if the tape, if still there, jives with it. Good luck.
