What do you like about the 2255?
ScooterBuck
11-09-2004 19:25:16
I found an Oliver 2255. It has front wheel assist and a cab with AC. I"m not sure what year it is. It has a CAT 3208 and seems to be in pretty good shape. The interior needs some work and the front tires need replaced but other than that it "looks" like it is a good tractor. It has almost 4,000 hrs on it. I really don"t know much about that style of a tractor and have not yet talked to the owner. I was told by a third party that it runs great and that everything works. Is it a good tractor or is it a model that may have a lot of problems with it? I"ve heard some bad things about the tractor not holding up like tranny problems and broken axles, how true is this? I think all of these problems came after "turning up the fuel pump" which I wouldn"t do. The most I would do is adjust the timing a tad if it had not already been done. How much money would be a fair price to offer? Any answers or additional information would be greatly appreciated. Thanks, Scott
VADAVE
11-10-2004 04:04:49
 Re: What do you like about the 2255? in reply to ScooterBuck, 11-09-2004 19:25:16
I haven"t heard of axles and such breaking just that the the rpm"s need to be keep up when working. Also they engines are to be rebuilt at 4000 hrs, although I don"t know what that is based on. The one i bought has 500 hrs on an engine rebuild and looks pretty good. I"ll need to find some front weights for it and probably duals and fix the AC.
I understand that while they were rated at 145 hp most came at 160+.
I bought it because I need to reduce the time spent riding in the field--I still work a full time off farm job and time is money. Besides I just like Olivers.
Ray in WA State
11-10-2004 07:25:02
 Re: What do you like about the 2255? in reply to VADAVE, 11-10-2004 04:04:49
Massy Ferguson used a 3208 Cat Engine in their 1400 series Tractor Didn't holdup good. they ran the engine at higher RPM,s than Cat Recomended. I believe Oliver didn't speed them up as much. My 2cents worth, Ray
